Enables RSVP-TE for the specified MPLS-configured VLAN.
| vlan | Specifies that RSVP-TE is to be enabled on one or more VLANs. |
| vlan_name | Identifies a specific VLAN on which RSVP-TE is to be enabled. |
| vlan all | Enables RSVP-TE on all VLANS that have been added to MPLS. |
Disabled.
When RSVP-TE is enabled, TE LSP establishment for configured LSPs begins and the processing of RSVP path/reserve messages from peer LSRs is permitted. By default, RSVP-TE is disabled for all MPLS-configured VLANs. Specifying the optional all keyword enables RSVP-TE for all VLANs that have been added to MPLS.
The following command enables RSVP-TE on the specified VLAN:
enable mpls rsvp-te vlan vlan_1
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
